Hello,
Issue solved. I was using Type-C - Type-C USB 3.2 100w cable and saw it doesn't support data transfer between Studio 24c and macOS. My research indicated that Studio 24c uses USB 2.0 protocol, so I am now using a Type-C to Type-A USB 2.0 cable with a USB hub. I ordered a USB Type-C to Type-C USB 2.0 so as not to use a USB hub. I will share my results with that cable again. Keywords: USB Sound assertion (Streams wrapping on different frames (off by 2) Edit after a few days: The cable has arrived, the issue is solved. Cable: Assmann Digitus AK-300138-018-S. |
