I just bought the 1810c and I have a couple questions.
What is the A/B button used for? What is the S/PDIF plugins used for? |
Welcome to the Forum!
Cue A/B (STUDIO1810c only). This button allows you to switch the source that you listen to through the Headphone 1 output. When the button is not illuminated, playback streams 1 and 2 will be routed to the headphone output. Press the button to route playback streams 3 and 4 to the Headphone 1 output instead. S/PDIF Input and Output. The S/PDIF connections allow two channels of audio to be transmitted and received at rates up to 24 bit, 96 kHz. The S/PDIF I/O also allows your Studio-series interface to send and receive word clock to external digital devices. Power User Tip: In UC Surface, you will need to set “S/PDIF” as the Clock Source and the sample rate to correspond to the external device when using an external S/PDIF device as your master clock. See Section 4.1 of the manual for details. Here's the download link for the manual... https://www.fmicassets.com/Damroot/Original/10001/OM_2777700401_Studio-1810c_EN.pdf
