Discuss Studio 2|4 / 24c, 2|6 / 26c, 6|8 / 68c, 18|10 / 1810c, and 18|24 / 1824c USB 2.0 Interfaces Here
What's the most economical way to pull this off? I'm using all 8 mic ports and just need one more.
StudioOne Professional (Sphere) w/ PreSonus 1824c
Recording Drums with 7 mic inputs
Computer: Intel Core i7-9700K 3.6 GHz 8-Core, MSI-7390A Pro, 32 GB DDR4-2666, Samsung 860 Evo 1 TB 2.5" Solid State Drive, EVGA GeForce RTX 2070 8 GB Black Video Card
by SwitchBack on Tue Nov 16, 2021 8:57 pm
Connect two (identical) mics to one input? Otherwise you'll have to get an adat mic pre for several 100 $$ (which then gives you 8 extra channels, most likely).
by Chuck37 on Thu Nov 18, 2021 8:02 pm
How do you do that? Just a splitter of some kind?
by SwitchBack on Sat Nov 20, 2021 4:08 am
The elegant solution requires signal transformers to manage impedances. The ‘in a pickle’ solution simply has two female XLR plugs to a male XLR plug. To check sound quality deterioration (due to the lower impedance the mics will see) record something first with one mic connected and then with two (the second mic muffled). Compensate for the lower level with two mics.
Or you can shop for the cheapest two mic input mixer you can find and use that for a submix.
