Freezing and clicking sound FL Studio when buffer is high.
Posted: Fri Aug 06, 2021 12:45 pm
by mustafaalr
Even if buffer is 2048 i cannot work with FL Studio but when i select FL Studio Asio it works.
When i select Studio USB Asio driver I hear click and popping sounds and FL Studio freezing.
Note: My laptop is powerfull and working with high performance plan.
Re: Freezing and clicking sound FL Studio when buffer is high.
Posted: Fri Aug 06, 2021 1:08 pm
by Bbd
Please provide your system specs and version #'s.
Thanks.
Posted: Fri Aug 06, 2021 1:40 pm
by mustafaalr
CPU: RYZEN 7 4800H
GPU: GTX 1650
RAM: 8GB 3200MHZ
HDD: SAMSUNG 980 500GB + 500GB STOCK SSD
DAW: FL STUDIO 20.8
WINDOWS 10 PRO
PORT: TYPE C
Posted: Fri Aug 06, 2021 4:31 pm
by Bbd
Sorry but is this a FL issue?
Do you own a Presonus interface?
Posted: Fri Aug 06, 2021 5:12 pm
by mustafaalr
I have Presonus 24C and I'm using FL Studio 20.8
Posted: Tue Nov 30, 2021 7:26 am
by 44345h
Yes I might be experiencing the same problem as you have.
CPU: i7-10875H
RAM: 32GB
SSD Hynix 1TB
Graphic: RTX2060mq
Interface: Studio 24c
Port: USB-C
Audio glitches terribly at buffer size of 1024 and 2048 smpls. 512 even better. I asked for support but presonus didn't give me a effective solution.
Tested on Nuendo 10.2.20, 11.0.40, 11.0.41 Studio One Artist 5.4.1.66992 FL Studio 20.7/20.8, 12.4 Cubase Element 11.0.40. There is no difference.
It is most likely a driver issue.
