I've tried a cheap DAC off Amazon that claims it converts LPCM and PCM signals from toslink or coaxial. I am using a 75 ohm RCA coax cable to connect from the S/PDIF output of the 1810 to this DAC and it does not work at all. The DAC specs include the settings I use in Pro Tools for post production work (44.1kHz, 48kHz, 96kHz, etc).
I use the 1810 with the UC mixer turned off and I use all 6 analog outputs to send separate signals to my speakers in my 5.1 surround sound mix room. I want to use the S/PDIF output as a stereo send to a headphone amplifier. I have created correct routing to the S/PDIF output in my Pro Tools I/O template and routed signal but it does not work. What do I need to make it work? Thank you Danny |
