I had to add a short section of wire from my guitar cable ground to the spdif ground on the back of the 1810c. Otherwise when I used my piezo pickup guitar (active type) I get a pretty decent hum.
Is this normal? I am OK with the wire (it is super clean now so pretty happy about that) but is there a better way to silence the hum? Extra info Guitar is a nylon string with piezo and mic. Only the piezo hums (there is a balance slider to select the pickup) I tried different electric outlets, same outlet, etc no effect on the hum I did have an old MOTU, it had the same hum with the piezo I also have an Axe FX II that is an interface, no hum from the Axe FX. I looked at the piezo preamp shielding it looks pretty decent so not sure adding more would help. If I touch the guitar cable ground the hum goes away. Of course not a good solution. Thanks! Ron
Hmm, and do you use the instrument or the line input setting for the 1810c's input?
If your guitar has a battery powered preamp following the piezo element then the signal may qualify as line level. That makes quite a bit of difference for the interface because the instrument setting is unbalanced and line setting is balanced. See if you can find a specification for your guitar/piezo pickup/preamp circuitry. It may actually need a (semi-)balanced connection for best results. The other challenge with any gear without power ground terminal is to prevent some of the usb signal to end up on the equipment's 'floating' ground plane/shell. If the reference level is noisy then inputs will have a hard time keeping that out of the input signals too. Interesting solution with that ground strap to the S/PDIF barrel. Put it in a ticket to PreSonus as it may help them get to the bottom of this. |
The Line button on the front panel is dis-engaged, so its using mic/inst
The gain trim for that channel is about 11 o'clock, so it would seem the signal level is within range of the input. This is the preamp, it does not mention balanced but it does say stereo capable, first I have heard of that. https://www.fishman.com/portfolio/prefi ... o-mat-p51/ |
