18|10 - Input balance on ins 5/6 and 7/8 out by 5-10 dB
Posted: Thu Jul 23, 2020 7:19 am
Hey there. Getting a strange issue with my 18|10 (B version).
Line inputs going into 5/6 and 7/8 in are imbalanced by about 5dB on ch6 and 10dB on ch8.
Steps taken to investigate:
Fired up a simple sine wave oscillator in Drambo (iPad). Incoming meter in UC clearly shows disparity in signal.
The signal is balanced when going into 1/2 and 3/4 (with all gain knobs set to minimum).
Switching the L/R jacks around shows the problem remains on the same channel (6/8 respectively). Have tried multiple cables.
I have also replicated the issue with other input sources (Peak and Octatrack). I can't see anything in UC that would be causing this (unless there's a pad I don't know about or something). Does anybody have any ideas, especially as to whether it's a hardware or software fault (jiggling the cables does nothing btw!)? It's meaning I'm having to pan offset everything post record which is proving a bit annoying.
Thanks in advance. a.:
