Hey there. Getting a strange issue with my 18|10 (B version).
Line inputs going into 5/6 and 7/8 in are imbalanced by about 5dB on ch6 and 10dB on ch8. Steps taken to investigate: Fired up a simple sine wave oscillator in Drambo (iPad). Incoming meter in UC clearly shows disparity in signal. The signal is balanced when going into 1/2 and 3/4 (with all gain knobs set to minimum). Switching the L/R jacks around shows the problem remains on the same channel (6/8 respectively). Have tried multiple cables. I have also replicated the issue with other input sources (Peak and Octatrack). I can't see anything in UC that would be causing this (unless there's a pad I don't know about or something). Does anybody have any ideas, especially as to whether it's a hardware or software fault (jiggling the cables does nothing btw!)? It's meaning I'm having to pan offset everything post record which is proving a bit annoying. Thanks in advance. a.: |
still no joy on fixing this.
Have now tried multiple cables and input sources. There is a clear drop in level in inputs 6 and 8. I use these rear inputs for hardware and, in the absence of space for a mixer, it's a really key element. Right now I can't do anything. Does anyone have any thoughts at all on what might cause this? a.: |
