Can anyone tell me if my 1810C should be left permanently plugged in and left on, or tuned off and unplugged when not in use? In my "day" there was a popular theory that anything electronic was actually better off permantly powered-up, because frequent (daily) power cycling did more damage than being left on. More than the unit itself, I worry about the power adaptor "adapting" power even when I'm not using the 1810C.
Thoughts?
Thanks!
by SwitchBack on Mon Jun 22, 2020 11:35 am
My straightforward rule of thumb: If it warms up you turn it off, if it stays cold you can leave it on. Good for safety, the environment and the gear itself (heat degrades electronic components).
Part B of that rule: let gear acclimatize before turning it on, to avoid unnecessary temperature stress. Usually says so in the manuals too.
There used to be a rule to keep anything spinning spinning (harddrives, fans, ...) but that’s outdated, because if you don’t turn them off then they will do so themselves nowadays :)
by GMHague on Wed Jun 24, 2020 6:18 pm
SwitchBack wroteMy straightforward rule of thumb: If it warms up you turn it off, if it stays cold you can leave it on. Good for safety, the environment and the gear itself (heat degrades electronic components).
Ah! That makes good sense! Thanks for that.
