Problem with Studio 1824c Headphone output 2
Posted: Wed Sep 04, 2019 1:15 am
by gftsuclj
The Studio 1824c is powered on with a large chance that the Headphone output 2 has no sound,The problem is solved when the control panel opens and the skip console is closed,But this problem really affects the experience,I don't know whether it's a hardware problem or a driver problem,Do you have any friends with similar problems?
Re: Problem with Studio 1824c Headphone output 2
Posted: Wed Sep 02, 2020 4:56 pm
by matthewwinne
I have the same problem. I'm using my Studio 1824c with Garageband and cannot get any sound from headphone output 2.
Posted: Sat Sep 05, 2020 8:27 am
by krisgeren
If your DAW is outputting on channels 1&2 - then I don't believe you will hear that output on the Headphone 2 jack, which monitors outputs 3&4....at least that's what I get from this section of the manual. It's similar to how my Focusrite 6i6 works so that you can setup different monitor mixes using sends:
Headphone Level. Your Studio-series interface provides two high-power headphone outputs, each with its own level control. Studio 1824c users will find both the headphone outputs and level controls on the front panel. Studio 1810c users will find the level controls on the front panel and the outputs themselves on the rear. On both units, Headphone 1 shares a stereo playback stream with the main outputs and Headphone 2 shares its streams with outputs 3 and 4. For Studio 1810c users, Headphone 1 can be switched between the two sets of streams via the A/B button.
