where is unity gain on 1824C
Posted: Fri Apr 26, 2019 2:32 pm
by hybridstudios1
i have an 1824c and just wondering where unity gain really is on the pods...
tracking an artist through my 6176 i find i have the pod almost directly in the middle number to have great levels. im use to interfaces that dont need to adjust for line.
i just want to be sure im getting correct levels or if i may need to turn the 6176 up. currently have the gain at +5 with the level at 6.5, input of the 1176 at 6 and output right at 5 but going through the 1824 fresh out the box the levels were non existent so i had to turn the line 3 pod up
let me know
thanks
Re: where is unity gain on 1824C
Posted: Mon Mar 16, 2020 7:44 am
by jeffdepascale
Old post but putting an answer in case anyone needs it.
Per the manual, line gain range on the inputs is -20db to +20db, so unity would be 12 noon.
Posted: Mon Mar 16, 2020 10:38 am
by darrenporter1
Only if the gain pots have a linear taper. If they are logarithmic then 12 noon will not be unity gain.
Posted: Mon Mar 16, 2020 12:10 pm
by SwitchBack
Or the other way around
Posted: Mon Mar 16, 2020 2:53 pm
by darrenporter1
SwitchBack wroteOr the other way around
Nope. Linear taper pot 50% will be 50% of the way through - halfway between -20 and +20 on the dial. To get to 50% on a log (or audio or A) taper pot you need to be around 2/3 of the way up or so... roughly.
http://www.resistorguide.com/potentiometer-taper/
Posted: Mon Mar 16, 2020 5:46 pm
by SwitchBack
darrenporter1 wroteSwitchBack wroteOr the other way around
Yes, only, dBs are logarithmic. So for a 'linear' dB scale (e.g.-20dB to +20dB with 0dB in the middle) you need a logarithmic / audio taper pot.
http://www.resistorguide.com/potentiometer-taper/ (a little further down)
Posted: Tue Aug 25, 2020 7:37 pm
by hybridstudios1
yea old post, never thought id get an answer so i put the 1824c in my sons room for him to use and got a Motu 1248
