i have an 1824c and just wondering where unity gain really is on the pods...
tracking an artist through my 6176 i find i have the pod almost directly in the middle number to have great levels. im use to interfaces that dont need to adjust for line.
i just want to be sure im getting correct levels or if i may need to turn the 6176 up. currently have the gain at +5 with the level at 6.5, input of the 1176 at 6 and output right at 5 but going through the 1824 fresh out the box the levels were non existent so i had to turn the line 3 pod up
let me know
thanks
by jeffdepascale on Mon Mar 16, 2020 7:44 am
Old post but putting an answer in case anyone needs it.
Per the manual, line gain range on the inputs is -20db to +20db, so unity would be 12 noon.
by darrenporter1 on Mon Mar 16, 2020 10:38 am
Only if the gain pots have a linear taper. If they are logarithmic then 12 noon will not be unity gain.
Studio One Professional 5.whatever, Harrison MixBus 32c v.6
UA Apollo QUAD, QUAD Satellite, PCIe DUO
FaderPort 8, Softube Console 1, JBL 306P Mk.II Monitors
by SwitchBack on Mon Mar 16, 2020 12:10 pm
Or the other way around ;)
by darrenporter1 on Mon Mar 16, 2020 2:53 pm
SwitchBack wroteOr the other way around ;)
Nope. Linear taper pot 50% will be 50% of the way through - halfway between -20 and +20 on the dial. To get to 50% on a log (or audio or A) taper pot you need to be around 2/3 of the way up or so... roughly.
http://www.resistorguide.com/potentiometer-taper/
by SwitchBack on Mon Mar 16, 2020 5:46 pm
Yes, only, dBs are logarithmic. So for a 'linear' dB scale (e.g.-20dB to +20dB with 0dB in the middle) you need a logarithmic / audio taper pot.
http://www.resistorguide.com/potentiometer-taper/ (a little further down)
by hybridstudios1 on Tue Aug 25, 2020 7:37 pm
yea old post, never thought id get an answer so i put the 1824c in my sons room for him to use and got a Motu 1248
