Saving 48V power setting
Posted: Thu Oct 04, 2018 4:42 am
by tonywhite5
I have a Presonus Studio 18/24 USB device controlled using the Universal Control application.
Is there any way to make the driver set the 48V power setting to ON and have it saved permanently?
The device is being used in an environment where it may get powered down and currently it does not retain its 48V setting, which is absolutely crucial for the use case it is being put to. The users will not have access to the physical buttons on the device and the PCs they're using will be locked down to prevent them from accessing the control panel, therefore the ability to permanently save the 48V setting is critical.
Any advice, anyone?
