I cant get any output from my lines 3/4 at the back of my Studio 26c audio interface. I connected a second set of speakers to 3/4 but nothing. 1/2 work fine so I tried swopping the cables over but still nothing.
Am I missing something? |
Yes, but only from software which allows you to select the outputs on an interface which has multiple (stereo) outputs. Many simple audio apps on a computer can only use one stereo output (usually the same output as used by system audio). Options to select this one stereo output on your interface depend on your operating system (Windows or MacOS).
Software designed to use more than one stereo output has its own menu for selecting outputs on interfaces that have them. This is done via the interface's native driver (e.g. PreSonus software will use the native drivers of PreSonus interfaces) or by using the ASIO or CoreAudio compatibility of those interfaces. DAW software and most DJ software works that way. I hope this helps you a bit further. If not then you have to provide way more information for more detailed advice |
All I have figured out is that I'm able to change from 1/2 to 3/4 as main outputs in windows OS sound settings. Also found that 3/4 outputs double as monitoring outs for the mic/line inputs. So when the "MON" button is lit on the front panel, outs 1/2, 3/4 and headphones all output whatever sound is coming through the mic/line inputs. Only outs 1/2 are volume controlled by the main. Only headphone out is controlled by headphone volume control. Outs 3/4 are unchangeable.
Maybe useful if you want to send an analog mic/line signal to something else such as a mixer, effects chain, recording device, speakers, amp. Anything that accepts a line level input. So this could be another way to get low mic signal converted to line level outs. Would be nice if there was a way to assign output 3 to only monitor input 1 and output 4 to input 2. |
