Capture tracks 33 +34 are greyed out after going from compatibility mode to 64 ch Mode and then back to compatibility mode. I can't seem to get the actual audio routed to input channels . i.e. Tape, Aux1 or Aux 2. It had been working as I had done some mixdowns within Capture to Capture Ch 33/34. prior to testing 64 ch mode after having the console serviced by Presonus to see if the compatibility issue was resolved after the service but it was not. . I can see there is audio present but I cant route it or hear it. Digital patching -->Input Patch -> USB shows USB 33/34 routed to Tape, Aux1 or Aux 2. Windows audio is routing to these channels Tape, Aux1 and Aux 2. Further when I try and create a new capture session there is no longer a track 33/34 created please advise.
Capture stereo track 33/34 by default gets receives its input signals via USB 39/40 (Main L/R) and the recorded stereo track is played back to the mixer via USB 39/40, which 'should' be Main L/R, but USB is not an input option for Main L/R. USB is simply not available as input source. So you need to make Aux In 1, Aux In 2 or Tape In 'see' USB 39/40 as inputs. As far as I know, Compatibility Mode changes the settings to USB 33/34, so the routing has to be changed accordingly.
Compatibility Mode is not so much a 'problem' of the StudioLive mixer, but more a problem of the computer. The mixer needs a few seconds for the internal restart, but the computer seems to need a full restart, alternatively a start after Compatibility Mode was established on the mixer. You can't 'toggle' between the modes. The computer will always need a restart. The stereo track of Capture will probably show again after a correct restart. |
"Compatibility Mode is not so much a 'problem' of the StudioLive mixer, but more a problem of the computer. The mixer needs a few seconds for the internal restart, but the computer seems to need a full restart, alternatively a start after Compatibility Mode was established on the mixer. You can't 'toggle' between the modes. The computer will always need a restart. The stereo track of Capture will probably show again after a correct restart."
Well Whalerstudios a restart worked!!! Thanks! There are many mysteries here not the least of which how is 39 and 40 are numbers between 1 and 34? Enquiring minds want to know;-) 4 years of engineering school and some how that topic was inexplicably overlooked. Maybe I nodded off in class? I am working hard to maintain my sense of humor on this sort of thing but it is very frustrating and time consuming at times. I would like to continue this conversation after I have done some further testing to see if given the above I can establish the routes I want to create. I would love to have a comprehensive "under the hood" white paper that documents this and as well as detailing the other "unsaid" aspects of the following from the Presonus "Compatibility Mode in Universal Control v4" document. Compatibility Mode Windows Audio Routing Explained. • o The USB routing while in Compatibility Mode should be as follows WDM Playback Device (To Mixer): 6x channel Device with channel indexes: • (Tape Input Left) default routing and name: "StudioLive WDM 1" • (Tape Input Right) default routing and name: "StudioLive WDM 2" • (Aux In 1 L) default routing and name: "StudioLive WDM 3" • (Aux in 1 R) default routing and name: "StudioLive WDM 4" • (Aux In 2 L) default routing and name: "StudioLive WDM 5" • (Aux In 2 R) default routing and name: "StudioLive WDM 6" WDM Recording Device (To Host): 8x channel Device with channel indexes: • (Ch 1) default routing and name: "StudioLive WDM 1" • (Ch 2) default routing and name: "StudioLive WDM 2" • (Ch 3) default routing and name: "StudioLive WDM 3" • (Ch 4) default routing and name: "StudioLive WDM 4" • (Ch 5) default routing and name: "StudioLive WDM5" • (Ch 6) default routing and name: "StudioLive WDM6" • (Main Left) default routing and name: "StudioLive WDM 7" • (Main Right) default routing and name: "StudioLive WDM 8" Digital Patching Options explained. • In Compatibility Mode, all USB Sends and USB Returns beyond the 34x34 available channels shall be grayed out on the mixer LCD and in UC Surface. When in 34x34 USB I/O Mode, the following Digital Patching will be in place • USB Send patch: o Channel 1-32 = USB 1-32 o Main LR = USB 33-34USB Return patch:Channel 1-32 = USB 1-32 o *Channel 33-64 = USB 1-32 (Mirrored) o Tape Input/Digital Return = 33-34*64S • USB Return patch: o Channel 1-32 = USB 1-32 o *Channel 33-64 = USB 1-32 (Mirrored) o Tape Input/Digital Return = 33-34 • *64S o For any other channel, patching should default to USB 1 There seem to be a few possible "you can't get there from here" aspects to the above. Thanks Again!!! Bill |
Ah, I see. Sometimes it's a little difficult to understand what is written. 😊 Basically, Capture has nothing to do with the WDM routing. It has and always had a 'fixed' 1-32 routing plus the stereo track, which is labeled channels/tracks 33-34, but the USB I/O is 39-40. Compatibility Mode changes the setting of the stereo track to USB I/O 33-34.
The WDM settings are Windows settings and you see the settings in UC Control in the Options tab (see screenshot). |
