I suppose the picture says it all, but here is what happened:
- after I tweaked some tracks I recorded through pipeline and my outboard gear (preamp, comp, eq) and got what I wanted I proceeded with printing/mixdown - before I did that, I didn't actually mess with anything in S1 (faders were at unity pretty much) pipeline's levels at 0, etc. - during the tweaking of comp, eq... when I was done the snare seemed to be a little bit louder than the rest of the tracks, at least when listening to playback, but I thouhgt I'd level that down after I print the outboard gear settings. - however, as you can see, it printed like 10db lower than the original signal (original signal is below it). I don't see how S1 could've be the culprit here, so I am suspecting as this was my first time using interface for this sort of thing that I might've overlooked something about interface mode or how it corresponds when outboard gear is involved. In any case, I'd appreciate your input as always. |
Users browsing this forum: No registered users and 17 guests
