I got my kick in mic going into my mixer at channel 1 (input 1) and my kick out into input 16.
They both are in a sub group on the flexmix 1. Now, if I wanted to run them through an outboard device, such as a compressor, would it work if I unchecked "main" on that subgroup, ran a cable out of the mix1 into the compressor and then from the compressor's output into one of the free line inputs in the mixer? This line input would in the end become a part of the drum bus (subgroup) that goes out to main... |
Great thanks.
If I ran a stereo pair, let's say a stereo bus compressor, would it work, in terms of recording, with S1 being the final destination, to send like overheads into the outboard compressor and return them into aux inputs 1&2? Those are 33&34 in usb routing, right? Obviously the main would be unchecked from the two overheads channels (in my case channels 7&8). I am asking this because I never tried to record aux inputs 1 and 2 into studio one. |
Actually, it's not necessary to add a stereo track. You can also use mono tracks for the stereo input channel - if that makes sense. The Studio One screenshot shows the USB routing of the StudioLive 32 Session template. Just the two tracks (33+34) needed to be added and moved to their position. New tracks are always added as last in the list.
