I've set up a matrix mix where I want main mix to control the mix 90% of the time.
Main mix is on the second set of scribble strips when i press the index arrow keys. Is there any way to move it to the front of this list (Aux Mix 1 is currently the first entry you see when you come into the matrix mix) Thanks, DT |
Matrix and aux mixes use a fixed scheme of channels, subgroups use selectable channels, so the answer is No. You would need to use the User Layer of the Series III consoles or the new User Layer of UC Surface, which has all the options. The screenshot shows the selection options of the UC Surface User Layer.
