Well how do I switch individual flex mixes back to normal mode?
Thanks a lot.
Btw I discovered a rather strange thing yesterday. I don"t know if routing on pipeline/mixer was wrong, but when I utilized the pream as external gear through pipeline I got a sort of negative latency. Meaning the snare drum track I was putting it through was like a half second sooner than all other tracks. Listening to it initially it just sounded it was behind everything, but it was off by like -0.5 secs. |
wahlerstudios wrote"Pipeline XT" has always been the way to do this, now "Interface Mode" is another option and sometimes a better solution. Using the Series III mixer in Interface Mode means that all available mix outputs (not Main L/R) receive their signals directly from the DAW. The technical realization is very similar to how you would send cue mixes to the outputs, meaning that USB sends 39-54 are used to "transport" the DAW signals. This is the routing: Wahler hi. One more question: Though I did not have time to go to my studio today, I was wondering, when in interface mode, where is the main L/R routed? Last time I tried interface mode I could not hear anything, including L/R. My studio monitors are connected to the mixer's monitor outs, so if all those outputs change, what happens with main? Thanks |
USB I/O routing in the 1-38 range is not changed at all, so you get the 32 input channels and the three stereo channels (Aux In 1, Aux In 2, Tape In). The mix bus of Studio One is routed to USB 37+38, which is Tape In on a Series II mixer. If USB is selected as input source for Tape In, you should hear the mix. Make sure that the settings for the Monitor section of the mixer are correct.
Ok
I got everything working, both interface mode and normal... However, I am still getting that strange latency. The pipeline detects what latency is going on, but after I engage it, the track that is on it is not in sync with other tracks. Maybe I should try a "real" interface made for this, instead going through the mixer? What do you think guys? |
Did you let Pipeline set the delay compensation? Have a look at this video for the details (4:55 for the delay compensation). And the StudioLive should be fine with Pipeline. A Thunderbolt interface will have a lower latency but that's Thunderbolt vs. USB rather than mixer vs. plain interface.
PS. You can't say I didn't warn you about latency |
Hehe yes you did.
Of course I let pipeline detect latency, IIRC it detected it around 45ms. But like I said in previous posts, something strange is happening: the signal that I run through outboard gear and back, that signal (that track) gets playbacked earlier-SOONER ....than all other tracks. I ran my snare drum .wav through it and initially I thought it was lagging behind, but upon closer listening, it was being played earlier than the rest of the tracks. As if pipeline moved all other tracks lagging behind it. They only way this works for me is with a single file inside studio one project, because obvioisly there are no other tracks that it could lag behind (or in front of) |
Just to let you guys that I solved the "latency" issue.
I went for interface mode on the mixer and simply muted all the channels on the mixer. I am now getting pure outboard mix within selected track. So the latency was coming out of some of the channels from the mixer. Not really sure which or how, but it works |
wahlerstudios wrote"Pipeline XT" has always been the way to do this, now "Interface Mode" is another option and sometimes a better solution. Using the Series III mixer in Interface Mode means that all available mix outputs (not Main L/R) receive their signals directly from the DAW. The technical realization is very similar to how you would send cue mixes to the outputs, meaning that USB sends 39-54 are used to "transport" the DAW signals. This is the routing: Wahler, hi. Something here is unclear to me. If output 1 and output 2, in interface mode, are USB 39 & 40. Then what are the USB outputs for MAIN? Thanks |
Main L/R is USB 39+40, but on the "input" side. I know, this is not really clear, but it's better to understand when you use the "mixer view". The mixer 'sees' 64 USB inputs from a DAW, which are the USB sends 39-54 for the direct signals to the flex mix outputs. It also 'sees' 64 USB outputs, like USB sends 39+40 for Main L/R to the DAW. The routing of USB inputs and USB outputs is completely separated.
I am not 100% I understood what you just said, but the reason why I am asking this is:
when in interface mode, and when I select the main output to be channels 37/38 (in S1), then that is actually being controlled by tape-in in the mixer as main output. However, when I use tape-in for this purpose I cannot get my outboard gear/pipeline to work without latency issues. That is, when the tape-in is used, there is significant delay with the track that is being used with pipeline plugin, it is impossible to mix that way. So, when I selected channels 39/40 to be my main outputs instead of 37/38 I get no latency issues and pipeline does what it PROMISES to do.... but those would actually be my mix 1 and 2 outputs. (by the way, I had to get out the interface mode, pan mix1 hard left, pan mix2 hard right in order to get a stereo main out that way). But this solution is making me use two outputs of the mixer to serve the purpose of a main out. If we exclude the tape-in, is this the only solution to get the main-out out in interface mode? |
