A new firmware version and a new UC Control/Surface version was released today. Check the download page of your mixer.
Firmware v2.6.0.90872 Universal Control v4.0.0.90879 |
Compatibility Mode reduces the USB I/O size (34x34). This should help the Mac issues and PC distortion (Intel Chipset compatibility).
It has to be turned on and your mixer must be rebooted. The mixer has a new PID, which means it shows up as a new device after switching, in all OS's. Unfortunately, Interface Mode isn't possible without the extra I/O, so that is disabled when using the reduced channel count.
I updated SL 16 and 32R without any problems, also UC Control/Surface on a laptop and an iPad and will continue with the other "stuff". So far, everything works, but testing always takes a long time. I like the new User Layer in UC Surface and that it's now possible to change the order of channels. This will make mixing via tablets a lot easier and more effective. I have no idea if I ever will use the new "Metro" feature, but I like the concept of a "mix conference". It will be interesting to follow the development.
The new layout of UC Control looks promising. A new layout for UC Surface should follow soon. The new devices already use a new design, which looks promising. 😊 |
I just saw this new Universal Control v4.0.0.90879 update in my account.
Was wondering is there something new/important in this update for Faderport 8/16 controllers? Should I install it considering I have Faderport 8? There are no mentions of changes or improvements for my device in the release notes. Thanks & cheers! |
Worked out very well!!!! finally, after so many years, it turned out to get a user layout. However, a couple of convenient things are still missing. In the user layout, you can add a general send mix, but you cannot add a send of a specific channel separately. That is, I would like to take the send of an instrument in a certain fx for example and place it in a user layout next to this instrument. For example, I have a microphone channel. I would like to place the send of the same channel next to it separately, for example, in fx1 and separately of the same channel in fx2 without affecting the sends of the other channels, but I managed to set only the entire send to the user layout. this is necessary so as not to run to the send mode and not to move the desired specific fader there, but to do it directly in the user layout by adding the desired fader from the desired mode right there. it really speeds up the work in big scenes when you have a lot of musicians and instruments and a lot of sends that you don't need to touch but only need to control one or two channels.
I would also really like to assign a color to the fx return - there is still no way to assign a color. It is very convenient to navigate by colors, especially when you work on a small screen at high resolution when all channels fit into the whole screen. that's where the problem comes from. On a large screen resolution, the equalizer, compressor, gate are very small. It's not convenient to use them. You have to aim accurately, it takes too much time. It may be worth adding the ability to change the size of the blocks in the program, for example, to shorten the channel faders and place the gate compressor equalizer limiter blocks not 4 in a row, but for example 2 in a row in 2 columns, thereby increasing their size. there is still a problem on mac . the update rate of the level meters is not saved. There are 3 modes, and each time it seems to be right as I need - slowly, but it doesn’t work like that. You have to manually first press quickly and then press slowly again, and only from that moment it becomes slow. But this problem is not in the new firmware. She has been for a long time. As soon as the function of changing the update time of the signal level indicators appeared. Now I sometimes use 2 laptops with 2 UC apps running. Or I do it on one laptop using 2 monitors. I just run 2 identical applications at the same time. You can use one monitor only in fader mode and the second monitor only in channel strip mode. Everything works well except for one very significant drawback. Having selected a channel in one application, it is not automatically selected in the second. If there was synchronization, it would be very convenient to work from two screens - on one screen, hold the faders on the second, highlighting the channel immediately shows its channel strip automatically. These are all my personal observations. And there are many of them, since I probably worked out 1000+ events in various places on studiolive in several years, since the console is operated by me personally - almost every day it moves from stage to stage, from club to club or concert hall. It is small and very comfortable. A great job has been done. Hope this develops further. |
There is the "Sync Select" function for each running UC Surface device, but it needs two or more CPUs. The number of screens connected to one laptop does not count. The photo from a rack mixer user in a Facebook group shows a nice combination of two touchscreens (laptop and screen part of an convertible).
wahlerstudios wroteThere is the "Sync Select" function for each running UC Surface device, but it needs two or more CPUs. The number of screens connected to one laptop does not count. The photo from a rack mixer user in a Facebook group shows a nice combination of two touchscreens (laptop and screen part of an convertible). i will try to test it today |
