Any way to use the headphone out on the 16r/24r/32r when in stagebox mode? My 32SC doesn't give any obvious patching options, and I want to throw the 16r in my drum room via AVB, and not have to use a headphone amp with an aux out for the drummer. Even mirroring the 32SC headphone out would be better than nothing (perfect waste of a good headphone out with volume knob). Thanks!
by SwitchBack on Mon Oct 25, 2021 5:50 pm
Hi and welcome to this forum :)
Hm, the headphone output needs the local solo bus and I don’t think that’s available in stagebox mode. The solution would be to avoid the stagebox mode altogether. It’s (mostly) only a quick way to configure the mixer in a way you can also achieve in normal mode anyway.
by davidbrown71 on Mon Oct 25, 2021 10:24 pm
So in normal mode I could route the headphone, mains, and solo signal from the 32SC to the 16r?
by davidbrown71 on Mon Oct 25, 2021 10:29 pm
I did figure out that the flex mix outs had enough juice to power my headphones. So I routed mix 1 and 2 outputs on the 16r to mix 1/2 (linked on the 32SC) using a Y splitter cable) Then I had to go into the Tape/PC channel and widen the stereo field.
