Long time RM16AI owner that uses virtual sound check extensively with a FireWire equipped laptop. I just ordered a 24R and after reading the manual have some concerns. Please help me understand the following:
1. To record into my laptop (via USB) and use Capture, the manual says that the device is the “only” device that can be used as control. Does this mean when I play back a session thru FOH as a virtual sound check, I will not be able to use my IPAD to make mixer adjustments. Is only the laptop (onstage with rig) the only way to make adjustments to the session playing. Or By keeping the 24R hooked into my router via the Ethernet “control” jack still allow my IPAD connected on the same network to control the mixer while he Laptop with Capture is playing back a session Thanks in advance - Justin And yes, my wife says I always have control issues
1. Where in the manual does it state that? and which manual document? That is not correct. I think there may be some context missing here.
2. Yes, you can use USB and Ethernet at the same time.
That’s great to hear. Was worried!
StudioLiveTM Series III Rack Mixers Rackmount Digital and Remote I/O System with AVB Owner’s Manual Page #6 (section 2.2.2) Your StudioLive Series III rackmount mixer can be connected directly to UC Surface running on a computer using USB. Please note: In this configuration, you can only use one device – your computer – to control your StudioLive mixer. |
Users browsing this forum: No registered users and 22 guests
