First a little background on my current setup: My home studio has a StudioLive 32SX connected to the Link port on a SW5E switch with PoE enabled and 2 Earmix 16Ms connected to ports 2 and 3.
My question is: can I connect two NSB 8.8s to port 4 and 5 without them getting damaged, considering that the SW5E has PoE enabled on all 4 ports? Will the PoE fry the NSBs? Thanks! Michael |
PoE very much works like phantom power. Devices not needing it will ignore it. From WikiPedia: "... This is possible because all versions of Ethernet over twisted pair cable specify differential data transmission over each pair with transformer coupling; the DC supply and load connections can be made to the transformer center-taps at each end." So self-powered (no PoE) devices will be galvanically isolated from the cables and won't pass (PoE) DC currents.
Having said that, probably with PoE the same rule applies as with phantom power: Make the connections first, and only then engage the phantom/PoE power. |
Thank you wahlerstudios and SwitchBack. After reading your replies, I went ahead and plugged in the NSB 8.8s into the SW5E and the StudioLive still recognizes them as active and available in the remote I/O setup, so all is good.
Also it appears that the SW5E recognizes that the NSB doesn't need it since the PoE light on the router is off for those 2 ports, but still lit for the 2 Earmix ports. Looks like PreSonus considered this setup but just didn't reference it in the manuals or videos. Thanks for the quick replies...you both are awesome! Michael |
Users browsing this forum: No registered users and 22 guests
