Hi. I cannot receive Efx from a microphone connected to NS8.8 in my headphones amp also connected to NS8.8.
I have the Efx in the main mix monitors and also in another send in another set of phones through a Hp60 headphone amp connected to the studio live 32 via XLR analog.I also have a NS16.8 connected and the reverb is not coming through the headphone amp connected to that either. Please Help. Regards Neil
by SwitchBack on Thu May 06, 2021 6:36 am
Hi and welcome to these forums :)
Sounds like you’re almost there. It would help if you let us know the input and output channels you are using, and which of the 4 FXes. Less confusion that way. And if you are using UC and/or UC Surface then let us know the platforms the apps are running on too.
by PAE Seth on Fri May 07, 2021 9:36 am
FX Returns can be sent to Main and Aux Buses.
NSB is just an extension of your mixer, but you must assign a Stream that has the Aux Outputs you desire in order to hear signal in the first place.
Sounds like you just need to raise the FX Return in the Aux Bus.
PC #2: ASUS X299 Prime Deluxe II, i7-7820X 8c/16t, 16GB 2666 MHz DDR4, GTX 1060 3GB, Samsung 970 EVO NVMe M.2 SSD (Win10 Pro), Samsung 860 EVO SATA SSD (Win11 Pro), OWC Aura 512GB NVMe M.2, 2 x 1TB HDD
Mac: 2010 Mac Pro 6 core 3.33 GHz, 32GB 1333 MHz DDR3, AMD RX 5500 XT 8GB, Alpine Ridge Thunderbolt 3 Card, Aquantia 10Gbps AVB card, Dual eSATA PCIe + Stardom 8xHDD Raid Tower
