Hey community,
I'm wondering how to use mute groups with the StudioLive 32SC!?
As far as I can see, there are no buttons for them and I don't want to use Universal Control for that.
Is there a workaround for it?
Best regards
Tom
by wahlerstudios on Fri Apr 16, 2021 9:59 am
There is no "workaround" for SL 32SC or SL 16. Mute groups are availaible in UC Surface only. You could use DCA groups as mute groups, also because it is possible to assign DCA groups to user layer. Or use the fixed subgroups... ;-)
by tomwolf3 on Sat Apr 17, 2021 10:49 am
So... is it possible to use a DCA group muting several inputs from different AUX mixes?
That is what I need to do.
by wahlerstudios on Sat Apr 17, 2021 11:10 am
No, DCA groups deal with the main mix level, so the mute function will work, but not for aux mixes. What you can do is to use the "Global Mute" function, which you can find on the first page of UC Surface settings. When this option is selected, muting a channel or send or return will mute it in all mixes.
May I ask why you want "mute several inputs from different AUX mixes"?
