Has anybody had any issue with losing fader control or intermittent issues when using the 32R as a stage box connected to studiolive mixer with cat5 cable?
While trying to get effects through aux's, I randomly lose fader control. Sometimes I can get effects but the faders will not control anything. Each piece works fine by itself, but together as advertised, they do not seem to work. |
Well, CAT5 isn't good enough so no surprise there. You have to use a CAT5e or CAT6 cable. And be careful with that cable. Kinks and pinches can deteriorate a UTP cable's performance to where communication becomes unreliable even if CAT5e or CAT6 is used. Also note that in a 32R in stagebox mode all local control is disabled. The console mixer will control the 32R's preamps (gain and phantom power) and that's it. Audio from the console mixer goes straight to the 32R's outputs. |
What SwitchBack said. Cables are the number 1 culprit for intermittent connections. AVB requires an even more consistent connection than most other protocols. Small packet drops can be very noticeable. Here is an article that will help you pick the best cables for AVB.
https://support.presonus.com/hc/en-us/a ... -AVB-Guide |
Users browsing this forum: No registered users and 17 guests
