Hey community,
I have a main mix and duplicated it to a linked stereo mix (aux) to make sure, that all settings are the same.
When I change the phones' setting from Main to Mix 1 / 2 it sounds completely different.
The main mix sounds much more "open", clear and wider in the phones.
Did I miss something?
by wahlerstudios on Mon Mar 15, 2021 6:22 am
When you copy a mix to an aux, this does not affect the stereo settings of input channels. By default, linked input channels are not "panned" in linked aux mixes. This has to be done manually. Then you should check if the aux mix is set to Pre1 or Pre2. If you want the full processing, Pre2 is the setting to choose. Also check the settings of the parametric equalizers on Main and aux sends.
by tomwolf3 on Mon Mar 15, 2021 8:00 am
Omg... you're a lif(v)esaver!
I really did not notice the panning difference. That did the trick!
Thank you so much.
