22 postsPage 2 of 2
1, 2
What does the "Copy Mix" function do?
The "Copy Mix" function is available for Main mix and aux mixes. Sometimes it can make sense to just copy a mix to another. You can also copy a mix to several aux mixes at once (if you want everybody to hear the same mix...). The copy function will not work for matrix mixes and subgroups, also not for effect mixes.
A quote from the UC Surface Reference Manual, section 2.2 Copy Mix:
Copying the current mix allows you to quickly set up multiple mixes based on the settings you’ve already completed.
1. To copy a mix to any other mix, press the Copy Mix button.
2. Click on the desired destination mix(es).
3. Click Paste to paste the mix or click Cancel to stop the operation.
Apple routers | iPads | Alesis iO Docks | Yamaha S112, S15e, S10e, SM12, SM10 | LD Systems Curv 500 | Galaxy Audio Hot Spots | Mac mini | Lenovo Laptop | Studio One Artist 5.0.0 & Pro 3.5.6
by wahlerstudios on Fri Oct 09, 2020 4:08 pm
Transferring project/scenes from one mixer to another
UC Surface Reference Manual, section 7.1.1 Import /Export: "Projects can be stored locally on your StudioLive mixer or locally on your computer* and copied between the two." (* or tablet)
Some things are really easy. ;-) You have a project/scene stored on your mixer and want to use it on a different mixer or take it with you as back-up. All you need to do in UC Surface is to copy the project/scene ("Mixer") to a computer or tablet ("Local") and from there to the next mixer. The screenshot is taken from the UC Surface manual.
22 postsPage 2 of 2
1, 2
