Overview Bugs
Posted: Tue May 07, 2019 7:24 am
by gierig
As there is no official List time start a Community one to keep track about some bugs.
Update with FW 2.1.16128 (actual Beta) that solve lots of bugs.
1.) A/B Handling unable to start over or remove Bank B settings
    Forum:
    https://support.presonus.com/hc/en-us/requests/507790
    Short:
    since FW 2.1.16128 Reset a Scene will also reset A/B and it work as expect. Good Work.
    Reset a channel will Only Flat out A/B so "B" will not start with a copy of "A" it will start
    with Flat Settings. That is better as before but still not very well..
    Workaround:
    Use a saved "from reset" Scence and use "Scene Safe" settings when you
    need fresh A/B from scrat for only one channel.
    Or be aware that a channel reset only FLAT Out "B" and not
    copy from "A"
    1.5) Saved preset will only restore to the A or B bank where the preset was made.
    Short:
    Save a preset will only restore to A or B bank where the preset was saved
    No change to load a “A” to “B” or vice versa.
    Workaround:
    You can Download the preset file, edit same remove the “memab” from a preset and put
    it back
2.) Flex Mix “preset Reset” Change AUX to Post
3.) SD Recall without Dynamics
4.) Ping Pong Daly work different on Mixer and UC
5.) Vintage Plate reverb, wrong Label on Mixer
    Forum:
    viewtopic.php?f=338&t=33345
    Short:
    Vintage Plate reverb shows on the "LF Damp Gain" a scale from
    0 to -12db. But it should go from -12 to 0db.
    Workaround:
    Be aware also Upper right corner show right values during changes, and UC is also right.
Re: Overview Bugs
Posted: Tue May 07, 2019 8:13 am
by bpierce
The first 3 issues are already logged and are slated to be fixed in the next firmware release. I'll check on the ping pong delay.
Re: Overview Bugs
Posted: Fri May 17, 2019 6:29 am
by gierig
add the Vintage Plate wrong Label Bug to the list that was report by wahlerstudios.
Re: Overview Bugs
Posted: Fri May 24, 2019 4:29 am
by gierig
FW 2.1.16128 (actual Beta) bring some bugfixes and improvements.
Summery:
are solved, good work
Reset a Scene will bring back the funktion to work as expect.
Rest a Channel will only flat out the "B" with helpful but not 100% right,
Still there and useless with A/B Handling. But if your aware or note the Bank in the File name
it still handy...
(btw. i can't also copy a "B" to a another "A" channel)
Still there even that is an mini minor level 99 bug...
