As there is no official List time start a Community one to keep track about some bugs.
Update with FW 2.1.16128 (actual Beta) that solve lots of bugs. 1.) A/B Handling unable to start over or remove Bank B settings
https://support.presonus.com/hc/en-us/requests/507790 Short: since FW 2.1.16128 Reset a Scene will also reset A/B and it work as expect. Good Work. Reset a channel will Only Flat out A/B so "B" will not start with a copy of "A" it will start with Flat Settings. That is better as before but still not very well.. Workaround: Use a saved "from reset" Scence and use "Scene Safe" settings when you need fresh A/B from scrat for only one channel. Or be aware that a channel reset only FLAT Out "B" and not copy from "A"
Short: Save a preset will only restore to A or B bank where the preset was saved No change to load a “A” to “B” or vice versa. Workaround: You can Download the preset file, edit same remove the “memab” from a preset and put it back 2.) Flex Mix “preset Reset” Change AUX to Post
viewtopic.php?f=338&t=34632 Solved with FW2.1.16128 Reset will in any case rest to AUX/PRE1 even you select subgroup or Matrix 3.) SD Recall without Dynamics
viewtopic.php?f=338&t=34642 Solved with FW2.1.16128 . 4.) Ping Pong Daly work different on Mixer and UC
viewtopic.php?f=338&t=34587 Solved with FW2.1.16128 and UC 3.1.0.52543 Work also with UC on Ipad as Expect. 5.) Vintage Plate reverb, wrong Label on Mixer
viewtopic.php?f=338&t=33345 Short: Vintage Plate reverb shows on the "LF Damp Gain" a scale from 0 to -12db. But it should go from -12 to 0db. Workaround: Be aware also Upper right corner show right values during changes, and UC is also right.
FW 2.1.16128 (actual Beta) bring some bugfixes and improvements.
Summery: 2.) Flex Mix “preset Reset” Change AUX to Post 3.) SD Recall without Dynamics 4.) Ping Pong Daly work different on Mixer and UC are solved, good work 1.) A/B Handling unable to start over or remove Bank B settings Reset a Scene will bring back the funktion to work as expect. Rest a Channel will only flat out the "B" with helpful but not 100% right, 1.5) Saved preset will only restore to the A or B bank where the preset was made Still there and useless with A/B Handling. But if your aware or note the Bank in the File name it still handy... (btw. i can't also copy a "B" to a another "A" channel) 5.) Vintage Plate reverb, wrong Label on Mixer Still there even that is an mini minor level 99 bug... |
