Anyone else having a problem with Qmix UC on android phones sharing a mix?
Two of my band members have Android phones. They both show up in the Device Permissions window. However, when I change the Mix allowed on one phone, it changes it for both phones. What I want is: Phone A is allowed Aux 3/4. Phone B is allowed Aux 5/6. (I use stereo mixes). If I set Phone A to Aux 3/4, it changes Phone B to the same Aux 3/4. If I then set Phone B to Aux 5/6, it changes Phone A to Aux 5/6. I can't seem to have the 2 phones on different mixes. Obviously this is not great, as the performers can't be adjusting each other's mixes. I'm on a 32R, latest firmware and latest software on everything, as far as I know. Is this a known issue? Is there a workaround? |
johnjeffers wroteDoes anyone in Presonus support read these forums? I can't find any info about this problem in the support area, and it's basically impossible for me to get the problematic phones and the mixer all in one place to call support during business hours. No, support, or any Presonus staff, do not regularly read the Forums. This is just for asking help from other USERS. I don't have any Android phones so I can't help ya or I would. . . To get help from Presonus support, you want to start a support ticket which you can do through your MyPresonus account. I don't recommmend calling support because of long wait times, but writing the ticket through the web usually gets you a reply fairly quickly. Steve
StudioLive RM32AI
No fix, but a workaround. Instead of granting access to a specific aux, grant access to all auxes. Then make sure that the users of the android phones have selected their correct aux.
Of course, the risk of this workaround is that someone will accidentally select the wrong aux and start adjusting someone else's mix. But it's better than the alternative. |
There is now an official answer of PreSonus: "This is a known issue and we are working to address it."
Can't get separate mixes on Android Qmix UC https://answers.presonus.com/35902/cant ... id-qmix-uc. |
2.10.0 and QMix-UC 2.4.0
It has come to our attention that UC Surface 2.10 and QMix-UC 2.6 is not working for some Android 6.0 customers. We are aware of the issue and are working on an update to be addressed in the next update. You can revert to the previous release you may so by downloading the previously available APK versions here: UC Surface 2.9.2 build 49805 This release will not allow switching from 48kHz to 44.1kHz QMix-UC 2.4.0 build 45212 I just got the info from Presonus South Africa. Reuben Thomas (no relation) found this for me. https://support.presonus.com/hc/en-us/a ... x-UC-2-4-0 |
Users browsing this forum: No registered users and 16 guests
