AVB Switch
Posted: Fri May 11, 2018 12:07 pm
by sheriffen
Hi.
Are there somebody who kan tell me how to setup AVB Switch for Presonus 32III / Presonus 32r.
Re: AVB Switch
Posted: Tue May 15, 2018 12:51 pm
by berdy24
You hook up both to the presonus AVB switch and any additional earmixes that require POE power. You can then set up all routing from the main mixer in the routing section. Make sure that the light is blue on the presonus AVB switch f you need power for ear mixes. Note that you need to set up the correct stage box mode for your rack mixer to get the desired setup. I hope this helps.
