At church I want our online live mix in a stereo and i want a separate mix (fat channel) for it so, can I do that?
Yes, of course. The "StudioLive_Series_III_OwnersManual_05042017" describes everything about the "Fat Channel" in section 5:
"The Fat Channel gives you powerful signal processing, mixing, and configuration tools for each channel and bus on your StudioLive. To begin working on a channel or mix with the Fat Channel, simply press its Select button. When you press a Select button, the number (and name, if applicable) of the selected channel or mix is shown on the touchscreen. Mix Select buttons can be accessed one of two ways: • Press the Mix/FX Masters button in the Bank section. This makes the mix and bus master faders available on the channel strips. Then, you can press the Select button that corresponds with the mix or bus you want to work with, bringing it into focus in the Fat Channel. • Press the Mix Select button that corresponds with the mix or bus you want to work with. The Master fader on the mixer surface then addresses the master fader for that mix or bus. Press the Select button above the Master fader to access Fat Channel controls for that mix or bus." https://www.presonus.com/products/StudioLive-32/downloads https://www.presonus.com/products/StudioLive-24/downloads https://www.presonus.com/products/StudioLive-16/downloads https://www.presonus.com/support/downloads |
ebctulsa wroteAt church I want our online live mix in a stereo and i want a separate mix (fat channel) for it so, can I do that? If I understand you correctly, you want to have a completely separate mix including channel EQ (FAT channel) for an online streaming mix? No you can't. But you can have a completely separate stereo fader mix. But the FAT channels for each input are shared. (This is a feature I would really love to have even for Artists monitors, but I have seen very few mixers that can actually do this. A full input routing matrix where you can send one input to two channels or more is the trick to do this but the Presonus mixers don't have an input routing matrix) Best way is to link a pair of AUX's and set them to PRE2. At that point you must let the FOH live sound guy/gal set the channel EQ (FAT channel) which will affect the Online AUX mix too, but you can adjust the pans and faders of every channel completely separate from the Live mix. You also have an output FAT channel on the entire stereo mix that you can use as a kind of Mastering for the feed. Steve
StudioLive RM32AI
