I tried to get the geq to work on the L/R and also an aux .. still does not work, it shows that it is assigned, Also did the firmware update today ..and still no geq .. any help is appreciated.
Permission is set to foh .. Listened thru l/r and geq has no effect on the sound at all, pushed the high end to try to make it feed back and still did nothing, Also there are 2 fx is there a way to make it 4 fx?
I just bought this thinking it would be a nice addition to my current mixers, But I am starting to have 2nd thoughts about it. |
Oh, sorry, I haven't realized this detail yet. The missing second processor is cutting features down. This is "on board" :
8 31-band graphic EQs 2 internal effects buses: combination of reverbs and delays with modern and vintage options 6 FlexMixes (can be designated as aux, subgroup, or matrix mixes) @ronron3: Do you have an idea why the equalizers do not work? @ stratman31: I can not see any reason why the GEQs should not work, so I would recommend to load the "Zero Out" scene and set the mixer back to factory settings. I guess the GEQs are routed then already (2 mains, 6 auxes), but they are disabled, as the manual says. Have a look, if this helps. |
Remember that it is not possible to hear the GEQs, if you are checking their functionality on the headphone/monitor bus. The graphic equalizers are routed directly to the physical outputs, so you will need to feed mains left/right or aux to an external headphone amp (or studio monitors, or PA) in order to check if the graphic equalizer works. If the GEQs decide to stay dead, there is no way to bring them back to life. Then it is necessary to open a support ticket and hope, that Baton Rouge takes care.
So yes, I am having the same issue with the GEQ on the Aux mix’s, and yes I have them set up correctly & turned on. (16R)
What is odd is that I got 1 Aux to work correctly in our first show, saved to the Scene, and it still works, however that’s all I can get... just the one that was the original? Tested with headphone, floor wedges, with a USB connect as well as an iPad. I have been using PreSonus since the very first 24.4.2, RM32/CS18 & had high hopes for the Series lll. File a ticket so we see what the response is. Latest firmware & latest version of UC Surface. I just wish the products were ready to go when released 🙈🙈 |
