Ok, not sure what I was doing wrong earlier; may have been trying to import into an existing project in Audacity, rather than a new one.
Now the settings from jamesnicholas3 above work: Encoding: Signed 24 bit PCM Byte Order: Little-endian Channels: 1 Channel (Mono) Start Offset: 50 bytes Sample Rate: 48000 Hz |
I just made this mistake myself and was scrambling trying to figure out how to recover the recording! A few things I learned along the way that I want to pass along in case they are useful to someone else.
First, here is the method that worked for me. I am using a 32R mixer and I recovered on a Windows 10 computer. Insert USB drive into computer Find drive in explorer and right click on it and select properties. Go to the tools tab Use error checking to scan the drive Close properties and go into the drive in explorer At this point, you probably only see the 0kb wav file. Type * into the search box to show all hidden files on the drive. Hopefully see a file with a name like FILE0000.CHK Copy this file (or similar) to your hard drive Open VLC Media player and Import this file into Audacity as a raw file with the following settings: Signed 24 bit PCM Byte Order: Little-endian Channels: 1 Channel (Mono) Start Offset: 0 bytes Sample Rate: 96000 Hz You should now have playable audio that you can edit and save as you wish. In case this method doesn't work for you, here are a few things I learned along the way: 1 - A useful tool to create a backup of the SD card is called Win32 Disk Imager. You can download it from here: https://sourceforge.net/projects/win32diskimager/ 2 - It was not clear to me that the backup file of the SD card was supposed to be imported as raw data into VLC. This partially worked for me but the results were nowhere near usable for my purposes. It is possible that this method will work too, but I did not bother to test it once I found the solution that worked for me. 3 - When importing the raw file, the audio was slowed down. This is because I used the wrong sample rate. Slow audio means you need to increase the sample rate. Doubling or cutting it in half is a good starting point. 4 - I actually had a similar situation happen the week after (sound tech didn't close session) and had to recover the wav file once again. But this time, the file was mostly static with true signal somewhat present. I tried importing as stereo instead of mono and found one channel was 100% static. I was able to separate the two channels and delete the one full of static. I think that's about it. Good luck to anyone else stuck in this situation! |
Users browsing this forum: No registered users and 18 guests
