I switched the Mix 1 bus to Subgroup mode.
How do I send sound to this subgroup from the input channels? In Aux Sends Mode the first Fat Channel controller and the button does not work. |
That was a bit cryptic, to me at least
The StudioLive subgroups work as subgroups in general work. They are mainly intended to organize FOH channels in groups so you can adjust the overall FOH level of a group from a single fader without changing the ratio between the channels in the group. Or you can use a subgroup to create a subset from the FOH channels e.g. for sending to subwoofers. The input faders and group faders are on different layers (banks). The 24- and 32-channel mixers can have channel faders on the left and group faders on the right. And on all mixer models you can mix and match using the user layer. Hope that helps |
