A couple of times my Studiolive 32 booted up with a blank screen. Another time the screen became blank in the middle of a session. Has this happened to anyone?
I have not had that on any public release firmware. What firmware version is in the mixer currently?
It may be a good idea to open a support ticket so this can be tracked correctly. |
The mixers are made to work in the temperature range between 0°C to 40°C, so temperature should not be the reason. I think you should ask Support for assistance. You can also check the cable connections inside the mixer, if the guarantee period is over already. It's something to check, but it doesn't necessarily lead to a solution.
I would suspect LCD screen connection is loose. Contact Support and find an Authorized Repair Tech.
