Hi all,
I'm looking to get some furniture designed around the SIII 32 - can anyone confirm if the side panels can be removed, as was the case with the AI models? Thanks, Andy Grinham |
There are a bunch of screws along each side and bottom (they look like torques or star) but I have not tried to remove them. It also looks like the sides are an integral part of the structure since the board is very thin (high wise) toward the front. You might want to build a desk that the board would drop or slide into from the front with the sides left connected (that is what I am thinking for mine). Hope that helps, p |
Officially I don't think the panels come off. For rack mounting the ears go over the sides (as per the mechanical drawings document.) Not sure what it does to your warranty when you remove the panels...
Users browsing this forum: No registered users and 19 guests
