26 postsPage 2 of 2
1, 2
It was said to be impossible
by babadono on Wed Aug 18, 2021 2:36 pm
Changing to 96K is a hardware as well as software/firmware issue the Series III can't go there :(
by jeremythornton on Sun Nov 28, 2021 5:40 pm
So since I have a new series 3 mixer, how do I change the sample rate to 44.1? I have a lot of songs that I've recorded using that rate and although I haven't seen a problem yet, I'd just like to not have any in the future. My DAW of choice right now is Cubase 10 Pro.
Unfortunately or not, it looks like I'm being forced to use Studio One. I'm not against doing that except for the fact that I'm very familiar with Cubase and at my age don't really fee; like spending all that much time learning a new DAW.
I have been watching a lot of tutorials on Studio One though just because it looks like my choice is limited, I'd much prefer Presonus just implement integration with Cubase and save me the trouble.
by wahlerstudios on Mon Nov 29, 2021 5:58 am
The sample rate settings can be found in the "systems" sections of touchscreen and UC Surface. You will need to have the latest firmware version installed to prevent problems caused by sample rates. And: Change sample rate of the mixer BEFORE starting your computer and NEVER change sample rate when mixer and computer are connected! The mixer is the clock and computer and DAW must "listen" to it.
There is nothing to say against Cubase. As long as you're not thinking of DAW Mode for Cubase, everything is fine... ;-) The StudioLive mixers work great as audio interface and monitor mixer.
I think you have seen the "SL32SC DAW Mode Cubase.pdf" already. If not, follow this link:
viewtopic.php?f=338&t=42810
by SwitchBack on Mon Nov 29, 2021 6:24 am
And you have to install Universal Control, which contains the drivers for the Series III products. Without UC and the drivers the computer may not be able to interface with the mixer correctly.
by PAE Seth on Fri Dec 17, 2021 1:51 pm
michaelfoss wroteIs presonus going to ever offer a 96K 24 bit upgrade to the studiolive 32R?! Or is that impossible? Mike
No, no plans to support 96k.
PC #2: ASUS X299 Prime Deluxe II, i7-7820X 8c/16t, 16GB 2666 MHz DDR4, GTX 1060 3GB, Samsung 970 EVO NVMe M.2 SSD (Win10 Pro), Samsung 860 EVO SATA SSD (Win11 Pro), OWC Aura 512GB NVMe M.2, 2 x 1TB HDD
Mac: 2010 Mac Pro 6 core 3.33 GHz, 32GB 1333 MHz DDR3, AMD RX 5500 XT 8GB, Alpine Ridge Thunderbolt 3 Card, Aquantia 10Gbps AVB card, Dual eSATA PCIe + Stardom 8xHDD Raid Tower
26 postsPage 2 of 2
1, 2
