Good News,
I was able to deconstruct my mixer configuration to a point where the problem went away and then isolate the problem to a few specific channels. In each of those channels I had used two EQ settings that you can switch between by using the Alt A/B switch. I had no sooner logged my findings into the ticket raised with PreSonus, then they responded that their engineering department had also found the problem to be with the Alt A/B settings in the scene file and they are working on fixing the problem. They are hoping to have the issue solved with the next release of the firmware, so until then mind the dual EQ settings. |
Help! - Just upgraded to a 16 channel studio Live Series III mixer. Also experiencing "saving scene" issues. The issue is intermittent but seems to happen after power down and power up. Also have experienced issues not being able to recall a scene. Is there a fix???
Did not have any of these issues with my Studio Live 24.4.2 |
louisdinafo wroteHelp! - Just upgraded to a 16 channel studio Live Series III mixer. Also experiencing "saving scene" issues. The issue is intermittent but seems to happen after power down and power up. Also have experienced issues not being able to recall a scene. Is there a fix??? What version of UC and Mixer firmware do you have installed? |
berdy24 wroteI had the same issue. After saving as the above person mentioned. the scene was not saved. Also the gain reduction VU meter does not work regularly on the vintage models of compressors. Is the compressor still compressing even though the meters are not working? (I have the most up to date firmware as mentioned above in original post.) I am having similar issues with my compressor. Is anyone else having this problem and is there a solution. I didn't really see an answer in the thread below. |
Are there knokn issues with assigned AUX-Mixes from SL 32 to SL 32R, wich I am not able to hear. I can hear nothing except a ambient noise. I run the newest Firmware on the SL 32 (1.7) , in 32R its Firmware 1.6. Is this the problem?
Maybe somebody can help me. Speck: I use iMac with Sierra, newest UC. Thank you all! |
