Question... I currently use a 32sx for my FOH mixer with a 32r as a stage box, I normally use Aux 16 for my lows so I can filter all unwanted frequencies to the lows, Then I run the FOH left and right normally. I know that a mix for the low front of house can be adjusted up or down independently as I currently have it, but I was wondering if there was a way when you move the Master fader while the Main Mix is selected, could you also control the relative mix of both the stereo Main Mix and the Aux mix? Basically wanting to control mix 16 with the Master fader as I control the FOH Mains at the same time?
That's what a Matrix is for, and that's likely what they are doing as well.
