● FaderPort 8 + 16: On/Off for individual send slots
● FaderPort 8 + 16: Display send or cue mix slot numbers on display Do I missing something? Can anybody explain how does this work? How to get with Faderport 8/16 On/Off individual send slots when there is more than one send slot each track? |
Check out sections 2.6.2 "Sends Mode" and 2.6.3 "Cue Mix Sends Mode" in the following manual:
https://pae-web.presonusmusic.com/downloads/products/pdf/FaderPort_16-8_OwnersManual_V5_EN_24092021.pdf Also here's a good video to check out:
Thanks @Trucky it works!
I also wish, that the Faderport bypass button does not make Insert slots On/Off but rather do what is label on the Faderport "bypass" Push button. Bypassing a plug-in is inside each SO plug-in window possible. (The native yellow button near the blue On/Off button) Maybe this functionality is not in Mackie Control mode possible. But maybe in native SO mode? The reason for this is: If you have a big song project with many tracks and VST plug-ins and "bypassing" all plug-ins simultaneously, (bypassing All) you will perceive a stutter effect when some plug-ins will have relevant latency values. (In playing mode) This is awful when switching vis a vis. To bypass all plug-ins and not making those always On/Off would be a solution for this. It also make sense the ability to suspend some plug-ins from global bypass. (On/Off) For example Sonarworks SoundID for loudspeaker correction. As a forum moderator you should give this Faderport request straightly to the PreSonus people. |
