Hello everyone!
I've recently bought a Faderport 16. Mainly to be able to write several automations at once. I understand how to do this for Volume etc, as well as how to assign VST-Effect parameters to the faders. What I struggle with is assigning VST instrument parameters to a Fader. This is how I do it: -I select VI on Faderport, to show my virtual instrument and select it. (bx-oberhausen in this case) -I touch the first fader on Faderport I want to assign. It shows up in top left area, see screenshot 1 - I click on the plugin parameter I want to assign (cutoff filter) It shows up in top left area, screenshot 2. -I click the little triangle to connect those (screenshot 3) --when assigning vst effects, this is now working, fx plugin parameter is controlled by fader 1. but not for VST instruments. When I move the Fader, it still only changes the Volume of the VSTi. -So I check in external devices, Faderport and can see that Filter Cutoff is assigned to Fader 1. (Screenshot 4)Focus is correctly on the VSTi. But it when I move Fader 1, it still moves the Mixer Volume of the VSTi, not the cutoff. What am I missing, doing wrong? I hope anyone can help me. Chilli edit: I wanted to add that it works perfectly and as expected with the knobs of my Atom SQ. |
