Hi there,
there are some bugs in the send section. The selection does not work as described in the manual. As soon as I have pressed the send button, I can set send 1 of the first channel with fader 1, then send 2 with fader 2! from the next channel ... etc. I.e. As soon as the fader is touched, it jumps to the other channel. The Sned key cannot be pressed again as described in the manual and nothing is possible with the Shift key. (Cubase 11 - Mackie Control - Further options: Cubase, as described in the manual) (Google Translate) |
I'm getting this same error. When attempting to edit sends or plugins (or channel EQ/comp) touching a fader selects one of the first 8 mixer channels and then edits the send/plugin parameter associated with the fader.
For example, when I want to adjust Send 1 on any channel it selects my first mixer channel and adjusts send 1 level, trying to adjust Send 2 on any channel selects the second mixer channel and adjusts send 2 level, etc. I've got Cubase 10.5 on my PC still and the same error happens with it too. |
