SOLVED - Faderport 16 w Logic Pro X 10.5.1
Posted: Fri Oct 23, 2020 8:39 am
by geoffduncan
Just wanted to post this in case other LPX / FP16 users were having the same trouble I was having.
Since updating, I could no longer use Pan (either from the knob or the Fader Pan mode), Solo and Mute clear no longer worked, and various other features were no longer functioning.
i ended up flashing the FP16 back to 2.02 and now everything works perfectly.
It seems like the UC / Firmware updates beyond 2.02 break the Faderport's Logic Pro x 10.5.1 functionality - but with 2.02 all features work correctly.
Including Solo clear, the panning functionality (from both the parameter knob and the fader 'Pan' function)
Here's what I did to fix -
- download UC 2.9.2 (the ''About Universal Control' shows version 2.9.2.49805 built Oct 19,2018)
- update firmware to v2.02
- power cycle the unit.
- select Logic mode.
Now it's working perfectly again.
Hope this helps someone! All the best
Geoff
Re: SOLVED - Faderport 16 w Logic Pro X 10.5.1
Posted: Thu Nov 05, 2020 9:49 am
by laurentparisi
Hi , lucky you, also the midi mode ? seems that in midi mode , fader don't send cc in logic 10.5.1 unless you "ignore surface control" ...
