45 postsPage 1 of 3
1, 2, 3
When I am mixing in Studio One 4.6 using the Faderport 16, the fader jumps up to zero db when I release my finger if I stop moving the fader at -2.7 db or louder. It is occurring on all of the faders.
Any suggestions?
Thanks.
Edit: I just noticed that this behavior only occurs when the "Shift" button has been selected. Is this fader behavior a bug or is there some logical reason for this? Seems like a pain to always have to be sure the shift button is not selected when using the faders.
Studio One 3.5. Windows 7 Professional x64 SP1. RME Fireface UFX.
by Bbd on Tue Feb 18, 2020 7:55 pm
Make sure you do not have any automation on the track.
Bbd
by robertcollins4 on Wed Feb 19, 2020 4:22 am
Bbd wroteMake sure you do not have any automation on the track.
I do not think there is any but will double check. Thanks.
by darrenporter1 on Wed Feb 19, 2020 10:43 am
this has been happening to me too, no automation involved anywhere in the song.
It started with the last firmware release and I can find no pattern of when, what fader, etc makes it happen.
Studio One Professional 5.whatever, Harrison MixBus 32c v.6
UA Apollo QUAD, QUAD Satellite, PCIe DUO
FaderPort 8, Softube Console 1, JBL 306P Mk.II Monitors
by robertcollins4 on Thu Feb 20, 2020 3:06 am
darrenporter1 wrotethis has been happening to me too, no automation involved anywhere in the song.
Is your Faderport also only exhibiting this behavior when the "Shift" button is engaged?
by darrenporter1 on Thu Feb 20, 2020 10:17 am
responded in my other thread, but I will check. Thank you.
by darrenporter1 on Fri Feb 21, 2020 12:27 pm
OK I had time to test this out this morning and YES I CAN confirm that this is ONLY happening when the FP8 is in a "shift lock" state; ie: the "shift" button is lit-up orange.
This needs to reported as a bug, but at least I know now what to do if it starts happening.
Thanks for helping to confirm that this is not just "all me" and a huge relief my hardware isn't broken!
by Jemusic on Fri Feb 21, 2020 2:48 pm
Its not a bug but a feature. It allows quick resetting of channel faders to unity if one wants to reset and start again from that position. Its actually really excellent once you start using it. Simply disengage SHIFT mode for normal operation. It is not hard to do.
Shift mode has alternate functions and will probably get more. Best to use Faderport in non shift mode for normal expected operation.
by darrenporter1 on Fri Feb 21, 2020 2:55 pm
Well then that feature sucks IMO.
Faders should always operate "normally" no matter what the shift state is. Having to verify that shift is not locked every time I want to adjust a fader is just nonsense and a workflow killer.
by Jemusic on Fri Feb 21, 2020 3:40 pm
It depends on how you look at it. It is not a workflow killer for me. It is an enhancement.
Undo will put any faders back if you have accidently moved them in Shift mode.
by robertcollins4 on Sat Feb 22, 2020 7:53 am
darrenporter1 wroteOK I had time to test this out this morning and YES I CAN confirm that this is ONLY happening when the FP8 is in a "shift lock" state; ie: the "shift" button is lit-up orange.
Thanks for documenting your find. After I saw the moderator's response I looked and did see it mentioned in the manual. (Page 8 I think.)
IMHO I think that it could be a useful option, but perhaps it would be better if we could enable this function using one of the "User" buttons. At least we are aware of it now and will have to work with it.
Cheers!
by frank.crow on Sat Feb 22, 2020 6:24 pm
robertcollins4 wroteWhen I am mixing in Studio One 4.6 using the Faderport 16, the fader jumps up to zero db when I release my finger if I stop moving the fader at -2.7 db or louder. It is occurring on all of the faders.
Any suggestions?
Thanks.
Wow
This happened to me this morning exactly as you described. I had 3 vocal tracks and was balancing using my F8 when the Fader on the first track snapped to Unity. I also suspected maybe some automation was written that I didn’t know about but nope that wasn’t the case. Weird that of the 3 vocal tracks only the first one exhibited this behavior. I use console scenes and have “Shift + All” enabled so my scenes are replicated on the F8.
Mac Mini (Late 2014)
Memory: 16 GB
Presonus. Studio One Pro V5
Presonus Quantum
Line 6. BassPOD XT Pro
Hardware DBX 160a
Hardware DBX 160XT
GA. Comp 2A
GA. Comp 3A
WA76 1176 (clone)
Softube. Console 1 MKII
Presonus. FaderPort & Faderport 8
"God's grace" :D
by frank.crow on Sat Feb 22, 2020 6:25 pm
Any suggestions?
Thanks.
Wow
This happened to me this morning almost exactly as you described. I had 3 vocal tracks and was balancing using my F8 when the Fader on the first track snapped to Unity. I also suspected maybe some automation was written that I didn’t know about but nope that wasn’t the case. Weird that of the 3 vocal tracks only the first one exhibited this behavior. I use console scenes and have “Shift + All” enabled so my scenes are replicated on the F8.
Memory: 16 GB
Presonus Quantum
Hardware DBX 160a
Hardware DBX 160XT
GA. Comp 2A
GA. Comp 3A
WA76 1176 (clone)
"God's grace" :D
by frank.crow on Sun Feb 23, 2020 7:33 am
Jemusic wroteIt depends on how you look at it. It is not a workflow killer for me. It is an enhancement.
It’s actually a significant inconvenience for me because I learned from a link on this forum to “Shift+All” so that my console scenes would be replicated on the F8. I mix in sections so moving from section to section or even just being able to jump to a section (group) to make an edit or update using scenes and having my faders ready to go has been great (actually a game changer) but now that is compromised.
Memory: 16 GB
Presonus Quantum
Hardware DBX 160a
Hardware DBX 160XT
GA. Comp 2A
GA. Comp 3A
WA76 1176 (clone)
"God's grace" :D
by darrenporter1 on Sun Feb 23, 2020 10:07 am
So yet another step to "fix" a workflow killer? yeah... that's helpful.... :thumbdown:
by darrenporter1 on Sun Feb 23, 2020 10:12 am
This hits the nail on the head right here... it neuters what I consider an essential function of the FP8/16... scenes and quickly navigating them. I have my navigation keys mapped to user F-keys and leave my FP8 pretty much shift-locked almost all the time.
Even when tracking I leave it shift-locked for easy one-handed access to Save and Undo.
by frank.crow on Sun Mar 01, 2020 4:52 pm
I put in a support ticket but I’m not too optimistic. I was reading the most recent manual and this behavior is actually listed as an updated feature.
Memory: 16 GB
Presonus Quantum
Hardware DBX 160a
Hardware DBX 160XT
GA. Comp 2A
GA. Comp 3A
WA76 1176 (clone)
"God's grace" :D
by darrenporter1 on Sun Mar 01, 2020 6:14 pm
Cool. Thanks for opening that. Be sure to point them to this thread so they can see that not everyone is thrilled about this "updated feature" they stuck us with!
by darrenporter1 on Wed Mar 18, 2020 10:28 am
frank.crow wroteI put in a support ticket but I’m not too optimistic. I was reading the most recent manual and this behavior is actually listed as an updated feature.
Did you get any feedback from Presonus on this? It's starting to drive me absolutely NUTS.
I am about to ask for the previous firmware so I can downgrade because this sucks.
by frank.crow on Wed Mar 18, 2020 2:06 pm
The tech asked me to send a spx file with the faderport connected. The response was that he was in the process of testing it out. But then he asked for a video of the problem. At that point I gave up because the issue I felt was super clear and I took it as an indication that it was going no where. My ticket was closed.
I actually just got a second monitor and put the console on that screen and I just bank.
It sucks but it will have to do for now.
Memory: 16 GB
Presonus Quantum
Hardware DBX 160a
Hardware DBX 160XT
GA. Comp 2A
GA. Comp 3A
WA76 1176 (clone)
"God's grace" :D
45 postsPage 1 of 3
1, 2, 3
