Im seriously tempted by the Faderport 16 but why is there no main volume fader?
Can the blue knob be assigned? |
fash40 wroteIm seriously tempted by the Faderport 16 but why is there no main volume fader? You have to press the yellow "Master" button in the "Session-Navigator". In this function the big blue encoder will control the main volume fader. Push the encoder to reset the master volume fader at 0db. Anyway..... Many people outside there are saying "don't touch the master fader at all". Leave it at 0db. |
In addition to the "Master Volume" on the big encoder, depending on what DAW software you use, the Master fader will appear in your mix. Just scroll it into view to control it. And because most often there is no need to adjust the Master fader constantly, no need for a dedicated fader for it. Just scroll it into view when you need it for adjustment or automation.
Cheers |
I'll hazard a guess here that the OP might have been referring to the lack of a main monitor pot, not a level control for the main stereo buss. If so, yeah, you're out of luck since the FP8/16 are software controllers only and do not have monitor facilities built-in.
On the flip side, this is part of what makes them so competitive price-wise with other similar-sized fader panels. And it allows people to configure their own setups as they wish--if someone wants a big $ controller (Dangerous Music, Coleman) they won't have those functions duplicated and unused in the fader panel. My needs are simple, so after I got rid of the OMNI I got a JBL NanoPatch that sits between the L/R outs of the 32R and my monitors. Steer the Studio One main mix to the correct outputs in the 32R, and now the JBL controls level and mute for the monitors. Works just fine. Peter |
Yes and I use a Presonus Central Station PLUS which I love.
As Dominque stated, you can get to the FP's Master fader easily.
Please add your specs to your SIGNATURE. Search the STUDIO ONE 5 ONLINE MANUAL. Access your MY.PRESONUS account. OVERVIEW of how to get your issue fixed or the steps to create a SUPPORT TICKET. Needs to include: 1) One Sentence Description 2) Expected Results 3) Actual Results 4) Steps to Reproduce. OS: Win 10 x64 Home, Studio One Pro 5.x, Notion 6, Series III 24, Studio 192, Haswell CPU: i7 4790k @ 4.4GHz, RAM: 16GB, Faderport 8/16, Central Station +, PreSonus Sceptre S6, Eris 3.5, Temblor 10, ATOM, ATOM SQ |
