Got my new faderport 8 and the left 4 LCDs are not working ...(bummer!)
Only time they are working is when the presonus logo shows. When resetting the DAW option (startup with 2 left "select buttons" pushed they are blank and when working in DAW also. (Studio One)
Anyone?
by jpettit on Wed Aug 02, 2017 8:18 am
First open a support ticket.
You can try running a calibration test with one of they'll menu options while in boot up configuration mode.
This might tell you more.
by RotaryFiend on Tue Jan 09, 2018 3:20 pm
I have this same issue....any word on resolution?
by matthewgorman on Tue Jan 09, 2018 3:24 pm
RotaryFiend wroteI have this same issue....any word on resolution?
If you can't exchange it from where you bought it, I would open a support ticket.
Matt
S1Pro V5
by SwitchBack on Tue Jan 09, 2018 3:36 pm
Hmm, sounds like a firmware issue. The logo showing at startup suggests that the hardware is fine. Which version of Universal Control are you running?
by chrisboshuizen on Tue Feb 06, 2018 1:11 am
I'm having the same issue, since the new firmware update the left 4 scribbles are sometimes blank. I power cycle it a few times and it eventually starts working. Did not see this on the older firmware.
by gdefosset on Sat Mar 16, 2019 11:08 am
I just picked up a used Faderport 8 seems to have this same issue with the right 4 lcds/scribble strips. About 30% of the time they don’t come on when powering up, switching off then back on will eventually get them to come up. Did anyone above ever figure out what the issue was? Loose wire inside, firmware issue?
by dan-stefanrucareanu on Thu Apr 11, 2019 8:56 am
I just bought a new Presonus Faderport 16 the other day. Having the same issue with the first four LCD screens.
There are times when they do not work. After switching off and on about a couple of times, they start working again.
Also, channel 9 does not show the correct name of the track after changing banks. It shows 0110101... (in Nuendo).
Is it firmware or shoud I send it back for exchange?
Thanks!
by Bbd on Thu Apr 11, 2019 9:02 am
Please open a Support ticket ASAP for your issue. They will guide you.
Bbd
by dan-stefanrucareanu on Thu Apr 11, 2019 9:22 am
Thank you, Bdb. Just did that. Good day!
by Bbd on Thu Apr 11, 2019 9:25 am
:thumbup:
Bbd
by gdefosset on Sat Jan 18, 2020 10:20 am
Was there a resolution to this? Same issue with right 4 lcds? Sometimes work sometimes have to turn on and back on to get to work.
