Sadly some of the faderport's functions which should work according to the manual, do not work in Cubase 9.
Some observations: When using compatibilty mode, which is suggested in the manual, I cannot use Pan, the Sends button doesn't even work. I can use the Edit Plugins button and use the Sends button to scroll through the pages. When using Cubase mode, everything works fine, except the Edit Plugins. I will get only one screen, and therefore am not able to scroll through the pages with any control. The parameters for the plugins are on page 2. The last part might be an user error, but using the faderport on VI channels is pretty annoying since it sends midi data to it, causing it to make noises when you use a fader. |
jeude wroteAlso, is there any way to use this thing in Cubase and NOT having it play notes when using buttons & faders on VSTi channels? This makes the whole thing completely useless for me. This is because you have all inputs as the selected input. If you want to use 'all' for inputs you need to make sure that the faderport isn't selected in 'all midi inputs' in the device setup-->midi port setup in cubase.
