Hey Guys
Received my Fader Port. I read the Instructions but cannot get it to see Studio One. I am running S1 Pro Ver. 3.3.3. I did download Universal Control and updated the Faderport to version 1.1 or the latest version it claims on screen. When I pull up Universal Control it shows Faderport connected but in the middle of screen it states to set it "Native Control" before using it with Studio One. I can add a picture if needed. Can someone tell me how to set Faderport to Native? In the manual it states the option will be given however I do not see it. There seems to be another issue also: When setting up Faderport in External Devices when I chose the Faderport 8 In / out it tells me the port is already in use and duplication could occur. Any help is appreciated. Don't want to open a support ticket if I don't have to. |
Shut down S1. Turn off the FP8. Then turn the FP8 back on while holding down the first two Select Buttons on the FP8. When it comes up you will have three options appearing in the LED boxes for the first three faders. Native Mode is the one on the left. Select it and you should be good to go.
Michael Morgan | pearl hour project --------------------------------------------------------------- Intel i7-2600 @ 3.4GHz | 16G ram Windows 10 | Studio One v3.3.1 | Live 9.6 (all software 64 bit) RME Fireface UFX | Nektar Panorama P1 | AKAI MPK25 | M-Audio Keystation 88 I Maschine 2 | Fader Port 8 |
pmsezztfs wroteShut down S1. Turn off the FP8. Then turn the FP8 back on while holding down the first two Select Buttons on the FP8. When it comes up you will have three options appearing in the LED boxes for the first three faders. Native Mode is the one on the left. Select it and you should be good to go. Thanks a lot. That fixed it!! |
pmsezztfs wroteShut down S1. Turn off the FP8. Then turn the FP8 back on while holding down the first two Select Buttons on the FP8. When it comes up you will have three options appearing in the LED boxes for the first three faders. Native Mode is the one on the left. Select it and you should be good to go. that fixed me too... |
